18 sonuçtan 1 ile 18 arası
Konu: 1.4 fire motor bloğu paslanma
    Standart Cevap: 1.4 fire motor bloğu paslanma
    O linkte data sheet i tiklaraniz aciklama var
    Zinc 600 derece
    Alu zinc 300 derece
    Alu 600 derece..
    150 derece hb de nerede?
    Hb, aluminium icin uygulamayi eksik yazmis gibi... nasit gorunsun diye distributor bu sekilde bilgi vermis olabilir mi acaba,..
    Isitmak gerekiyor sonra... 160 derece,30dakika
    Technical Informationen Aluminium Spray - motipdupli.com
    Application
    Remove residues of old paint and rust.
    Slightly sand.
    The surface has to be possibly blank to the metal, clean, dry and fat-.
    Shake can for 3 minutes before use.
    Spray a distance of approx. 25 cm
    Abstand several thin coats:- Layer thickness approx. 20-30 μ-
    The thinner the layer, the better the temperature-resistance.
    After approx. 1 hour drying time, heat up for approx. 30 minutes (160°C) in order to cure the lacquer coat.
    Hereby you have to reckon formation of smoke and unpleasant odour. Care for sufficient ventilation.
    Zinc
    High-grade zinc coating more than 90 % zinc share in the dry film
    Cathodic corrosion protection for all blank metals
    Resistant to highest demands against corrosion
    Highheat-resistant up to 600°C
    Particularly suitable for welding seams
    Ideal for all metals in outside places, which are liable to rust
    Aluminium
    99,5 % durable, pure aluminium according to DIN 1712
    High-heat-resistant up to 600°C
    Protects corrosion and weathering influences
    Suitable for misc. surfaces, such as iron, cast iron,stainless steel; the compatibility on aluminium andnon-ferrous metals has to be tested before at aninconspicuous spot.
    After tempering resistant to dilluted cleansers
    Silver metallic, satin glossy; slight decline of gloss afterextreme heating
    Konu timbaz tarafından (02/09/2016 Saat 22:53 ) değiştirilmiştir.
  1. Paslanma !!!
    halilimo tarafından Teknik Yardım forumunda yazıldı.
    Son Mesaj: 01/08/2016, 16:29
  2. Fiat Kaportada Paslanma!!
    Son Mesaj: 17/11/2015, 14:35
  3. Fiat Aracımın Motor Bloğu Pas Tuttu.
    Son Mesaj: 02/02/2015, 12:35
  4. 1,5 Yıllı Punto Evomda Paslanma Var
    gizemlierkek tarafından Teknik Yardım forumunda yazıldı.
    Son Mesaj: 25/08/2011, 18:23
  5. Diskteki paslanma
    hulukardesler tarafından Araç Bakımı ve Temizlik forumunda yazıldı.
    Son Mesaj: 24/04/2009, 16:58
