[CENTER]1,3 euro 4 75 hp dynamic+asistkit+ skydome evo grisi
1-KOLTUK KILIFI
2-VİOLENCE 30CM (SLİM SUBWOOFER) SLİM KUTU
TASARIM ÖZELLİKLERİ
- 12" (305mm) Black Poly Mica Cone
- Foam Surround
- 2" (51mm) High Temperature
Kapton Voice Coils
- 500W RMS / 1000W Max. Power
- Frequency Response 32Hz to 2.3KHz
- Sensitivity 90dB (1 watt / 1 meter)
- Impedance 4 Ohm
- Mounting depth 4.1/8" (105mm)
3-VİOLENCE V-A490 CLASS STRERO AMPLİFİKATÖR
TASARIM ÖZELLİKLERİ
- Kompakt boyut ve küçük ayak izi
- Çift taraflı PCB and SMD kart
- Full Mosfet tasarım
- LPF ve HPF crossover tasarımı
- Gürültü önleyici tasarım
- Fazla güç ve fazla ısınma korumaları
- Düşük ve Yüksek Voltaj Koruması
- Rohs uyumlu
TEKNİK ÖZELLİKLER
RMS@2 (Power supplier14.4V)..............4×90W
RMS@4 Bridged (14.4V)......................2×180W
Input Level ..........................................0.2V-5V
Channel Input Adjust.................................YES
CH-A Filter Mode ..........................HP-FULL-LP
CH-B Filter Mode...........................HP-FULL-LP
CH-A HPF ....................................50Hz-750Hz
CH-A LPF ....................................50Hz-750Hz
CH-B LPF ....................................50Hz-750Hz
CH-B HPF ....................................50Hz-750Hz
Frequency Response ...................10Hz-25KHz
THD at 4ohm load 30% rated power .....<0.05%
S/ N Ratio ...........................................>90dB
Channel Seperation ..............................>89dB
Minimum Load ......................................2Ohm
Overload protect system .........................YES
Overheat protect system....................80C/176F
Components & PCB .SMT & Double side board
Dimensions (LxWxH)....266mm×204mm×56mm
4-HERTZ DSK 165 16 CM COMPENANT İTALYAN
Comp: 2 Way system: High density flux ferrite magnet, water-repellent pressed paper cone woofer + DT16 tweeter. Factory provided seperate crossovers DX100,DX200
Sensitivity: 93dB/SPL
Power Handling: 120W Peak Power, 60W Continuous Program Power
Frequency Range: 50Hz - 21Hz
Impedance: 4 ohm
Model: DSK 165
Türü: Hoparlör
Boyut: 165mm(6 inc 1/2) Woofer, 15mm(19/32inc) Tweeter
Güç Kullanımı: 120W Peak Power, 60W Continuous Program Power
5-Sony XSF-1737SE 17 cm 3 Yollu Hoparlör
Çap
17 cm
Maksimum çıkış gücü (W)
200
Nominal çıkış gücü (W)
Etkin frekans aralığı
50-24K
Çıkış ses basıncı seviyesi
89±2 dB (1 W,1 m)
Nominal Empedans (Ω)4
6-Direkler karbon kaplama
7-KROM CAM ÇITALARI
8-CAM FİLMİ 2 NUMARA (Artık baya açıldı Rengi 1 numara gibi oldu )
9-Marspiyel (Murat Gökdepe Abiden aldım)
10-Spoiler (Murat Gökdepe Abiden aldım)
11- Hiojin-HRS 16'' Jant H 490 DMGM modeli
12- Lassa İmpetus Revo 205/55/R16 Lastik
13- Ön krom Matfolyo kaplama
HER GÜN İŞE GELİP GİTTİĞİMDEN 50000 İ BULDUK.
BAKIMLARIMIZ EDREMİT KARAHALLILAR DA YAPILMAKTA VE SERVİSİMİZDEN MEMNUNUM ÇOK ŞÜKÜR.
BUGUNE KADAR KÜÇÜK SES PROBLEMLERİNDEN BAŞKA SORUN YAŞAMADIM.
ÖN CAM FİTİLLERİ RÜZGAR SESİ(UĞULTUSU) YAPTIĞINDAN
ARKA KAPI MENTEŞELERİ AÇILIRKEN SES YAPTIĞINDAN,
SAĞ ARKA KAPI AÇMA MEKANİZMASI ARIZALANDIĞINDAN,
DEĞİŞTİRİLDİ.
HERKESE KAZASIZ BELASIZ GÜNLER DİLEĞİYLE
bir kaç foto güncelledik 3. Sayfada
Konu ersobas tarafından (18/10/2012 Saat 12:53 ) değiştirilmiştir. Sebep: Yeni eklentiler.
Güle Güle Kazasız Belasız Ve Cezasız Bin Kardeşim Maşallah...
"Ulaşılmaz Olduğumuz Söylentisi Doğru Değil.Sadece Çocukların Ulaşamayacağı Yere Koyduk Kendimizi..."
Bazı fotolar bunlar sayfa ikide yeni hali var
Konu ersobas tarafından (12/10/2012 Saat 12:30 ) değiştirilmiştir.
Maşallah, kazasız belasız sürüşler olsun.
Buda benim beyaz meleğim....
sade ve şik biaraç gülegüle kullan.
Ceza konusunda hakikaten cam filmi sorun oluyo bergama dikili taraflarında polisler filmleri bir kaç kere sorun oldu ama şimdi sol arka cam filmini söktüm ben durdururken de ön camları indiriyorum gittiği yere kadar artık. Hayırlısı ya yaptırırken rengi açılır falan demişlerdi bu kadar açıldı.
Jantları değiştirmek istiyorum lastikleri de değiştirme zamanı geldiğinde ama bakalım uygun bir şeyler bulurum umarım.
Maşallah kazasız belasız
Marhaba
Benim Punto'nunda fotoğraflarını çekip koyalım ben böyle havalı fotoğraf çekemiyorum . Saygılar Lapsekideyim Çardak beldesinde
güzel sade ve hoş..
Filmleri 3m çektir polis bişey diyemez çünkü vizeden geçen şeye ceza yazamazlar kardeşim
Aracta BulunanLar;
Spor yay 6.5 cm
H4 25000 Kw exzenon Mavi
H7 35000Kw exzenon Pembe
Performans Chip dual
4 takım mid Violence power Serisi
1 adet 3000 watt 750 RMS Bass Violence
1 Adet Jbl 304 Mid anfisi
1 adet Violence 1600.1 bass anfisi
1 adet kapasitor 5 farat
HondaCivicYeni KasaSimota OrjinalPerformans FiltreKiti
Bagaj iptali
benimde aile gelibolu da yaşıyor zaten arabada oranın plakasından çekeriz tabi ya hafta sonları geliyorum arada bn zaten arabayı da çardakta iskelede bırakıyorum geliboluya geçirmiyorum. çok bişey yapmadım çekmek için zaten ya sadece yıkattım alışveriş merkezi otoparkına gittim Samsung p1000 tabletle foto çektim. çok amatör aslında fotolar
güle güle kullan araban gayet güzel. benim de beyaz renkte cam filmi çok belli oluyor. her an cezayı yapıştırabilirler.yersem ceza sökücem. kimse ile uğraşamam. ama 3m cam filmine de isterse polis ceza kesiyor. arkadaşımın başına geldi. muayeneden geçiyor cezayı da yiyiyor. böyle saçma sapan bir iş işte. neyse. kazasız belasız inşallah.
2010 Beyaz Punto Evo 1.4 77hp Fire Dualogic Dynamic + Skydome + Asistkit + Güvenlikkit +Popkit + Bordo
Orjinalin hali herzaman başka , kılıflara takıldım sadece
güle güle kullanın.
Tadımlık
TSİ Jetta.
kazasız belasız kullanman dileği ile..
kılıf seçiminiz hoşuma gitti hazırmı aldınız diktirdinizmi ve kırmızılı olanı varmı? bir kaç leke oldu koltuklarımda bende kılıf düşünüyorum
1.3 DYNMC 5K. METALİK BEYAZ AS.KT. - Hİ-Fİ - SKY-DOME - FR.KT. ABARTH I SPOİLER
Kılıflaeı bn hazir aldim gri renk doseme leke yapacakmis gibi geldi banada bide renk solmasi fln yapmasi diye taktirdim ama baya iyi gerdirdiler ufak tefek asinmalar olmaya basladi ama ne yazikki kaliteli bir seydegil amacina uygun olsun korusun mantigi aslina bakarsaniz bizim koltuklar kendinden sekilli yani uyduruk bi kilif alininca bile iyi oturuyor gibi geliyo bana tesekkurler herkese
Güle güle kullanın allah kazasız belasız günler nasıp etsin inşallah
maşallah kazasız belasız... skydome ın kattığı hava süper
maaşallah güzel araç...
Keyif BMW'Dir...
