Konu: Fiat Araçlar Almanya Tüv Lastik ve Jant ebat Ebatları
    şükrü t
    punto57 - ait Kullanıcı Resmi (Avatar)
    Evo Metalik Beyaz
    Edilen teşekkür: 61
    Standart Fiat Araçlar Almanya Tüv Lastik ve Jant ebat Ebatları
    veriler bilgi amaçlıdır
    sadece bilgi, belirli aralıklar verilmiştir Offset değerlerinde,
    Jantın tasarımı göz önüne alınmalıdır.
    ayrıca x factörlere bakılmalıdır.
    isteyene pontoların fren diyagramıda vardır elimde
    doblolarda iki farklı type ( kasa kodu yazdım 263 ve 223)
    Fiat
    Fiat 500 (51kW, 55kW and 73,5kW)
    type 312
    ABE/EWG number e3*2001/116*0261*..
    technical perm. front wheel load 385-415 kg
    technical perm. rear wheel load 320-368 kg
    PCD 4/98/58,1
    fixing element (screw) Schraube M12x1,25
    max. jut out of the screw 18,0/18,5 for all versions, the max. out of the screw for each version see blow.
    note max out of the screw: 73,5kW (brake 257mmx22mm): max. 21mm; 55kW (brake 240mmx20mm): max. 21mm;
    51kW (brake 240mmx11mm): max. 18,5mm
    possible wheelsize and offset
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    5,5x14 25-26
    5,5x14 27-29
    5,5x14 30-38
    5,5x14** 35 175/65R14
    6,0x14 24-27
    6,0x14 28-31
    6,0x14 32-33
    6,0x14 34-37
    6,0x14 38-40
    6,0x15 25-27
    6,0x15 28-29
    6,0x15 30-31
    6,0x15 32-32
    6,0x15 33-37
    6,0x15** 35 185/55R15
    6,0x15 38-40
    6,0x15** 40 185/55R15 (only 73,5kW)
    6,5x15 25-28
    6,5x15 29-29
    6,5x15 30-30
    6,5x15 31-33
    6,5x15 34-34
    6,5x15 35-38
    6,5x16 24-26
    6,5x16 27-27
    6,5x16 28-30
    6,5x16 31-37
    6,5x16** 35-35 195/45R16
    7,0x15 25-26
    7,0x15 27-27
    7,0x15 28-28
    7,0x15 29-31
    7,0x15 32-32
    7,0x16 25-28
    7,0x16 29-30
    7,0x16 31-33
    7,0x16 34-34
    7,0x16 35-37
    7,0x17 24-26
    7,0x17 27-29
    7,0x17 30-30
    7,0x17 31-33
    7,0x17 34-35
    7,5x16 25-26
    7,5x16 27-27
    7,5x16 28-28
    7,5x16 29-30
    7,5x16 31-32
    7,5x17 24-26
    7,5x17 27-28
    7,5x17 29-29
    7,5x17 30-31
    7,5x17 32-32
    Fiat
    Fiat Fiorino
    type 225, 225L
    ABE/EWG number e3*2001/116*0271*.., N157
    technical perm. front wheel load 450-475 kg
    technical perm. rear wheel load 475-490 kg
    PCD 4/98/58,1
    fixing element (screw) / SW Schraube M12x1,25 / SW 17
    max. jut out of the screw 17,5 - 25
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    5,5x14 30-33
    5,5x14 34-41
    5,5x14 41-45
    5,5x14** 44-44 =175/70R14
    6,0x14 30-32
    6,0x14 33-35
    6,0x14 36-40
    6,0x15 30-32
    6,0x15 33-35
    6,0x15 36-39
    6,0x15 40-44
    6,0x15** 44-44 =185/65R15
    6,0x16 30-31
    6,0x16 32-36
    6,0x16 37-40
    6,0x16 41-42
    6,0x16 43-45
    6,5x15 30-34
    6,5x15 35-38
    6,5x15 39-42
    6,5x15 43-44
    6,5x16 30-34
    6,5x16 35-38
    6,5x16 39-40
    6,5x16 41-44
    7,0x15 30-32
    7,0x15 33-37
    7,0x15 38-38
    7,0x16 30-32
    7,0x16 33-36
    7,0x16 37-38
    7,0x16 39-40
    7,0x16 41-42
    7,0x17 30-34
    7,0x17 35-38
    7,0x17 39-40
    7,0x17 41-44
    7,0x18 30-34
    7,0x18 35-38
    7,0x18 39-40
    7,5x17 30-32
    7,5x17 33-36
    7,5x17 37-38
    7,5x17 39-40
    7,5x17 41-42
    7,5x18 34-37
    7,5x18 38-38
    Fiat
    Fiat Doblo
    type 263
    ABE/EWG number e3*2007/46*0002*..; (LKW -geschl. Aufb.) e3*2007/46*0007*.. (PKW)
    technical perm. front wheel load 538-560 kg
    technical perm. rear wheel load 538-725 kg (PKW 538kg-585kg / trailer 625kg; LKW570kg-655kg / increased load capacity 725kg)
    PCD 5/98/58,1
    fixing element (screw) / SW Schraube M12x1,25 / SW17
    min/max. jut out of the screw 18/21
    note -
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    5,5x15 22-40
    5,5x15** 39 =185/65R15
    6,0x15 22-40
    6,0x15** 39 =195/65R15
    6,0x16 22-35
    6,0x16 36-39
    6,0x16** 36,5 =195/60R16C
    6,0x16 40-40
    6,5x15 22-23
    6,5x15 24-27
    6,5x15 28-33
    6,5x15 34-37
    6,5x15 38-39
    6,5x15 40-40
    6,5x16 22-23
    6,5x16 24-27
    6,5x16 28-33
    6,5x16 34-36
    6,5x16 37-37
    6,5x16 38-39
    6,5x16 40-40
    6,5x17 22-23
    6,5x17 24-37
    7,0x15 22-25
    7,0x15 26-27
    7,0x15 28-29
    7,0x15 30-31
    7,0x15 32-34
    7,0x15 35-35
    7,0x15 36-39
    7,0x16 22-26
    7,0x16 27-29
    7,0x16 30-31
    7,0x16 32-33
    7,0x16 34-34
    7,0x16 35-36
    7,0x16 37-39
    7,0x17 22-23
    7,0x17 24-26
    7,0x17 27-34
    7,0x17 35-37
    7,5x16 22-24
    7,5x16 25-28
    7,5x16 29-32
    7,5x16 33-34
    7,5x16 35-36
    7,5x17 22-25
    7,5x17 26-29
    7,5x17 30-31
    7,5x17 32-36
    Fiat
    Fiat Doblo Modelljahr 2006
    type 223, 223L
    ABE/EWG number e3*98/14*0071*06-.., K750 ab NT 11
    technical perm. front wheel load 450-505 kg
    technical perm. rear wheel load 515-635 kg
    PCD 4/98/58,1
    max. jut out of the screw 17 - 25
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    5,5x15** 32-32 =185/65R15
    6,0x15 25-27
    6,0x15 28-30
    6,5x15 26-27
    6,5x15 28-28
    Fiat
    Fiat Doblo
    type 223, 223L
    ABE/EWG number e3*98/14*0071*.., K750
    technical perm. front wheel load 450-485 kg
    technical perm. rear wheel load 515-530 kg
    PCD 4/98/58,1
    fixing element (nut/screw) Schraube M12x1,25
    max. jut out of the screw/length of the bolt 17/26
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    5,5x14** 37-37 =175/70R14
    6,0x14 25-31
    6,0x14 32-35
    6,0x15 25-27
    6,0x15 28-30
    7,0x15 25-25
    Fiat Grande Punto
    type
    199
    ABE/EWG number
    e3*2001/116*0217*..
    425-500 kg
    425-475 kg
    PCD
    4/100/56,6
    Schraube M12x1,5 / SW 17
    18 - 20,5 !
    note
    Punto 2005
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    6,0x15 33-36
    6,0x15 37-40
    6,0x15 41-43
    6,0x15** 43-43 175/65R15
    185/65R15
    6,0x15 44-45
    6,0x16 34-37
    6,0x16 38-40
    6,0x16 41-43
    6,0x16 44-46
    6,0x16** 45-45 195/55R16
    6,5x15 33-34
    6,5x15 35-37
    6,5x15 38-41
    6,5x15 42-45
    6,5x16 35-38
    6,5x16 39-40
    6,5x16 41-43
    6,5x16 44-46
    6,5x17** 46-46 205/45R17
    7,0x15 33-37
    7,0x15 38-40
    7,0x16 30-35
    7,0x16 36-40
    7,0x16 41-42
    7,0x16 43-45
    7,0x17 34-38
    7,0x17 39-43
    7,0x17 44-45
    7,0x18 35-39
    7,0x18 40-43
    7,5x16 33-38
    7,5x16 39-42
    7,5x17 33-35
    7,5x17 36-38
    7,5x17 39-40
    7,5x17 41-42
    7,5x18 34-36
    7,5x18 37-40
    Fiat
    Fiat Linea
    type 323
    ABE/EWG number e3*2001/116*0260*..
    technical perm. front wheel load 500 kg
    technical perm. rear wheel load 450-518 kg
    PCD 4/98/58,1
    max. jut out of the screw 17 - 21
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    6,0x15 30-31
    6,0x15 32-34
    6,0x15 35-38
    6,0x15 39-44
    6,0x15** 44-44 =185/65R15 /195/60R15
    6,0x15 45-45
    6,0x16 30-34
    6,0x16 35-39
    6,0x16 40-42
    6,0x16 43-45
    6,0x16** 45-45 =195/55R16
    6,5x15 30-33
    6,5x15 34-37
    6,5x15 38-40
    6,5x15 41-41
    6,5x15 42-45
    6,5x16 30-33
    6,5x16 34-37
    6,5x16 38-41
    6,5x16 42-43
    6,5x16 44-45
    7,0x15 30-32
    7,0x15 33-36
    7,0x15 37-39
    7,0x15 40-42
    7,0x16 30-31
    7,0x16 32-35
    7,0x16 36-39
    7,0x16 40-41
    7,0x16 42-43
    7,0x17 30-33
    7,0x17 34-37
    7,0x17 38-41
    7,0x17 42-43
    7,0x17 44-45
    7,0x18 30-33
    7,0x18 34-37
    7,0x18 38-41
    7,0x18 42-43
    7,5x16 32-34
    7,5x16 35-39
    7,5x16 40-40
    7,5x17 30-31
    7,5x17 32-35
    7,5x17 36-39
    7,5x17 40-42
    7,5x18 30-31
    7,5x18 32-34
    7,5x18 35-36
    7,5x18 37-40
    7,5x18 41-42
    8,0x17 32-33
    8,0x17 34-37
    8,0x17 38-38
    8,0x18 32-34
    8,0x18 35-36
    8,0x18 37-38
    Fiat
    Fiat Qubo ( fiorino)
    type 225
    ABE/EWG number e3*2001/116*0271*..;
    e3*2007/46*0011*..
    technical perm. front wheel load 475 kg
    technical perm. rear wheel load 475 kg
    PCD 4/98/58,1
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    6,0x15 30-32
    6,0x15 33-35
    6,0x15 36-39
    6,0x15 40-44
    6,0x15** 44-44 185/65R15
    6,0x15 45-45
    6,0x16 30-31
    6,0x16 32-36
    6,0x16 37-40
    6,0x16 41-42
    6,5x15 30-34
    6,5x15 35-38
    6,5x15 39-42
    6,5x15 43-44
    6,5x16 30-34
    6,5x16 35-38
    6,5x16 39-40
    6,5x16 41-44
    7,0x15 30-32
    7,0x15 33-37
    7,0x15 38-38
    7,0x16 30-32
    7,0x16 33-36
    7,0x16 37-38
    7,0x16 39-40
    7,0x16 41-42
    7,0x17 30-31
    7,0x17 32-34
    7,0x17 35-35
    7,0x17 36-38
    7,0x17 39-40
    7,0x17 41-44
    7,0x18 30-34
    7,0x18 35-38
    7,0x18 39-40
    7,5x17 30-32
    7,5x17 33-34
    7,5x17 35-36
    7,5x17 37-38
    7,5x17 39-40
    7,5x17 41-42
    7,5x18 34-37
    7,5x18 38-38
    Fiat
    Fiat Punto Evo
    type 199
    ABE/EWG number e3*2001/116*0217*..
    technical perm. front wheel load 425-500 kg
    technical perm. rear wheel load 425-475 kg
    PCD 4/100/56,6
    fixing element (screw) / SW Schraube M12x1,5 / SW 17
    max. jut out of the screw 18 – 20,5
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    6,0x15 30-32
    6,0x15 33-36
    6,0x15 37-40
    6,0x15 41-43
    185/65R15
    6,0x15 44-45
    6,0x16 30-33
    6,0x16 34-37
    6,0x16 38-40
    6,0x16 41-43
    6,0x16 44-46
    6,5x15 30-32
    6,5x15 33-34
    6,5x15 35-37
    6,5x15 38-41
    6,5x15 42-45
    6,5x16 30-34
    6,5x16 35-38
    6,5x16 39-40
    6,5x16 41-43
    6,5x16 44-46
    7,0x15 30-32
    7,0x15 33-37
    7,0x15 38-40
    7,0x16 30-35
    7,0x16 36-40
    7,0x16 41-42
    7,0x16 43-45
    7,0x17 30-33
    7,0x17 34-38
    7,0x17 39-43
    7,0x17 44-45
    7,0x18 30-34
    7,0x18 35-39
    7,0x18 40-43
    7,5x16 30-32
    7,5x16 33-38
    7,5x16 39-42
    7,5x17 30-32
    7,5x17 33-35
    7,5x17 36-38
    7,5x17 39-40
    7,5x17 41-42
    7,5x18 30-33
    7,5x18 34-36
    7,5x18 37-40
    Fiat
    Fiat Bravo
    type 198
    ABE/EWG number e3*2001/116*0248*..
    technical perm. front wheel load 500-525 kg
    technical perm. rear wheel load 430-480 kg
    PCD 4/98/58,1
    fixing element (nut) / SW Schraube M12x1,25 / SW 17
    max. jut out of the screw/length of the bolt 17,5 - 21
    note
    wheelsize
    OE** single
    offset [mm]
    min-max tire
    (if standard)
    6,0x15 22-24
    6,0x15 25-26
    6,0x15 27-35
    6,0x15** 31,5-31,5= 195/65R15
    6,5x15 22-24
    6,5x15 25-28
    6,5x15 29-35
    6,5x16 22-24
    6,5x16 25-26
    6,5x16 27-28
    6,5x16 29-30
    6,5x16 31-32
    6,5x16 33-35
    7,0x15 24-26
    7,0x15 27-28
    7,0x15 29-31
    7,0x15 32-35
    7,0x16 23-27
    7,0x16 28-30
    7,0x16** 31-31= 205/55R16
    7,0x16 31-31
    7,0x16 32-35
    7,0x17 22-24
    7,0x17 25-27
    7,0x17 28-35
    7,0x17** 31-31 =225/45R17
    7,5x16 23-26
    7,5x16 27-29
    7,5x16 30-32
    7,5x16 33-35
    7,5x17 24-26
    7,5x17 27-29
    7,5x17 30-35
    7,5x18 24-26
    7,5x18 27-29
    7,5x18 30-31
    7,5x18 32-35
    7,5x18** 35-35 =225/40R18
    8,0x17 23-25
    8,0x17 26-28
    8,0x17 29-32
    8,0x17 33-33
    8,0x17 34-35
    8,0x18 24-25
    8,0x18 26-28
    8,0x18 29-32
    8,0x18 33-33
    8,0x18 34-35
    Konu punto57 tarafından (14/03/2015 Saat 12:31 ) değiştirilmiştir.
    şükrü t
    Evo Metalik Beyaz
    Edilen teşekkür: 61
    Standart Ce: Fiat Araçlar Almanya Tüv Lastik ve Jant ebat Ebatları
    Lastik muamması yaşayan arkadaşlar okuyun şunları
  1. Jant ve lastik ebat seçimi ?? yardım.. punto 1,3 mjet
    bedulcouse tarafından Modifiye forumunda yazıldı.
    Son Mesaj: 09/03/2013, 14:26
  2. Lastik Ebatları
    fotobelit tarafından Lastik ve Jant forumunda yazıldı.
    Son Mesaj: 02/10/2012, 12:10
  3. Lastik ebatları
    Son Mesaj: 05/06/2012, 01:37
  4. Lastik ebatları acil
    hsyn28 tarafından Teknik Yardım forumunda yazıldı.
    Son Mesaj: 23/04/2012, 17:37
  5. Lastik ebatları
    hakanyilmaz tarafından Teknik Yardım forumunda yazıldı.
    Son Mesaj: 13/08/2010, 11:24
