Hayırlı satışlar .
Arkadaşlar HDMI girişi olan herhangi bir ekranı boyutu ne olursa olsun bu cihaz sayesinde Android bilgisayara cevirebilirsiniz. Air mouse/klavyesi ilede özgürce kullanabilirsiniz. İnternet, müzik, video aklınıza ne gelirse... Resimler ürünün birebir aynısının temsili resmi akşam eve gidince gerçek resimlerini eklicem.
Airmouse/klavye ile bilgisayarda kontrol edebilirsiniz. Cihazın bir tarafı mouse diger tarafı klavye otomatik geciş yapıyor.
2sine birden toplamda 225tl istiyorum kargosu bana ait. İzmir içi elden teslim edebilirim.
MK802 III Dual Core RK3066 1.6Ghz A9 Android 4.1.1 Mini PC
Main features:
Model
Rikomagic MK802 III
Dimension
90 * 40 *13 mm
Net Weight
0.25kg
Material
Plastic
CPU
Rockchip RK3066; Cotex A9, 1.6GHz; GPU: Quad- Core 2D/ 3D/ OpenGL ES2.0(AMD Z430)/ OpenVG1.1
Operation System
Android 4.1 (Jelly Bean)
Memory
DDR3 1GB
Nand Flash
4GB
Android Market
Yes
Youtube / Flash
Yes, Support Adobe Flash 11.3
Video
Support AVI, RMVB, MKV& FLV Video Format, Support 1080P HD Playback
Music
MP3/WMA/WAV/APE/AAC/FLAC/OGG
Ebook
TXT, PDF, HTML, RTF, FB2…
Skype
Yes, but this device does not built-in microphone / camera.
HDMI Interface
Yes, it can support following HDMI output mode:
- 480I / 480P
- 580I / 580P
- 720P (50Hz / 60Hz)
- 1080i (50Hz / 60Hz)
- 1080P (24Hz / 50Hz / 60Hz)
Email and Browser
Yes, built in
WIFI
Built-in 802.11 b/g/n
Power
powered via USB cable / Power charger (5V 2A)
Current of TV: should be ≥500mAh(5V), when lower than 500mAh, external power supply to the TV box is needed
Language
Dutch, Indonesian, Catalan, Czech, Danish, German, English, Spanish, French, Croatian, Italian, Latvian, Lithuanian, Hungarian, Malay, Norwegian, Polish, Portuguese, Roman, Slovenian, Finnish, Swedish, Swahili, Vietnamese, Turkish, Zulu, Greek, Ukrainian, Russian, Serbian, Bulgarian, Hebrew, Arabic, Persian, Thai, Bengali, Korean, Japanese, Simplified Chinese, Traditional Chinese
Other Applications
Office, Browser, Gallery, Clock, Calculator, Calendar, Taskiller, Gmail…
Extend Port
1 x HDMI port
1 x MicroSD (TF) Card Slot
1 x USB Power port
1 x USB 2.0 Host port (wired keyboard; 2.4G keyboard, mouse, hand grip, etc)
QWERTY Keyboard
-2.4GHz DSSS radio transceiver, 30m/100 feet maximum distance
-Dimensions: 169 x 48 x 19mm
-Weight: about 160g/0.35 pound
-Computer system requirements: Microsoft''s Windows 2000, XP, Vista, 7 or Linux tested
-Wireless (RF 2.4G) ion, smart and portable size
-To enjoy PC multimedia entertainment at home
-Works Google''s Android box and Smart TV
-Convenient and efficient for conference, presentation and lecturing
Bravo HGTurbo
Kaan
Hayırlı satışlar .
KarŞıYaKa
Muhteşem bir ürün.. Teknolojiyi yakalamak imkansız.10 sene önce şu günleri hayal bile edemezdik. Şu android olmasaydı ne yapardık biz![]()
Şu an heryerde herşeyde androidBüyüksün Android
KarŞıYaKa
g u n c e l
Bravo HGTurbo
Kaan
hyr sadece 2 forumda ilanım var.
Bravo HGTurbo
Kaan
Guncel...
HTC Wildfire S cihazımdan 2 ile gönderildi
Bravo HGTurbo
Kaan
Hocam ben böyle bir ürün almayı düşünüyorum. Satma nedeniniz nedir acaba? Bir de bu ürünün marka ve modelini net bir şekilde yazar mısınız?
Bravo HGTurbo
Kaan
guncel 200tl kargo haric
Konu punto_multijet tarafından (05/03/2013 Saat 11:08 ) değiştirilmiştir.
Bravo HGTurbo
Kaan
İLANI DİKKATSİZ OKUYAN ARKADAŞLAR İÇİN NOT:
Özel msjdan şu şekilde bir mesaj geldi. gönderen arkadaş iyi niyetli zaten o belli ondan nickide sildim yanlış anlasılma olmasın.
Şimdi burada arkadasın dikkat etmediği bir nokta var ki belki baska arkadaslarda vardır aynı noktada takılan acıklama yapayım. Bu bana gönderilen ilan sadece ana ünite için! Hatta ilanı dikkatli okursanız ilanın en altında ayrıca almanız gereken cihaz olarak airmouse cihaz gösteriliyor. Bu cihazı kullanabilmeniz için airmouse tarzı bir ürüne ihtiyacınız var ki cihazı kontrol edebilesiniz. Yoksa sadece ekrana bakarsınız hiçbirşey çalıştıramazsınız. yani benim lanımdaki 200TL lik fiyat hem ana ünite hemde airmouse 2si birden yaniİyi günler, ilk önce ürün almak için mesaj atmıyorum sadece bilgilendirme amaçlı mesaj atıyorum arkadaşım bilgine olsun
Bu ürün sanırım senin ürün ile aynı çok incelemedim sıfır fiyatı 178TL yazıyor. Kolay satmak için fiyatını revize etmen lazım sanırım.
Hayırlı satışlar...
MK802 III Dual Core RK3066 1.6Ghz A9 Android 4.1.1 178 TL Sanalpazar.com'da
Bravo HGTurbo
Kaan
buarada linki gönderen arkadasa tesekkurler en azından onun sayesinde karsılastırmada yapabilirsiniz. İlan burada 178tl + olarak aynı kişide benim yanında verdigim airmouse 81tl yani 2si toplamda 259tl yapıyor ki aynı 2 ürün benim ilanda 200tl.
Bravo HGTurbo
Kaan
